Links
Old 05-08-2008, 09:33 AM   #1 (permalink)
Default Exhaust manifold bolts
I found some grade 8 locking washers at the local hardware store. Would it be ok to use those instead of the flat washers when remounting the exhaust manifold? they are about a thread thicker than the flat washers.
Thanks!
Rob
rturbett is offline   Reply With Quote
Old 05-08-2008, 10:22 AM   #2 (permalink)
Grade 8 is a bit overkill but they should be fine. I used the same but in a Grade 5. Don't forget the liberal use of antiseize compound...
'95 RRC LWB, '05 Suburban Z71 (not stock), '94 F350 (very ugly), '62 International 404 tractor (red & white) & many other project cars in the past!
57loboy is online now   Reply With Quote
Old 05-08-2008, 02:46 PM   #3 (permalink)
I'm a big fan of stainless steel bolts, flat washers and lock washers for this particular application.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 05-08-2008, 02:50 PM   #4 (permalink)
Elemental's Avatar
Fine??? Its PREFERRED! Thats exactly how I do it.
exhaust manifold loose wimp Discovery Series II 8 03-25-2008 08:00 PM
what kind of steel are the exhaust bolts made from??? bargecapt Range Rover Classic 4 03-17-2008 09:16 AM
cracked exhaust manifold... stolenheron Discovery Series II 11 12-29-2007 10:10 PM
Broken exhaust manifold stud skucera Range Rover Classic 7 12-24-2007 08:21 PM
Exhaust manifold advice DougG Range Rover Classic 9 11-26-2006 12:36 PM
