Old 03-14-2008, 09:02 AM   #1 (permalink)
ChamplianRover
Default Fluid Change Help
Not too long ago I was reading up on how to change differential/viscous coupler/differential fluids on rangerovers.net.
Now I can't find it. It had diagrams and excellent step-by-step instructions.
Can anyone help direct me to the link?
Thanks,
ChamplainRover
ChamplainRover is offline   Reply With Quote
Old 03-14-2008, 10:03 AM   #2 (permalink)
This one?
Range Rover Transfer Case Oil Change
Kevin
88 RRC "Audrey"
Old 03-14-2008, 01:54 PM   #3 (permalink)
ChamplianRover
That's the one.
Thanks, Kevin!
ChamplainRover
Old 03-14-2008, 01:57 PM   #4 (permalink)
ChamplianRover
BTW,
Are you the Kevin that provided that link to RangeRovers.net? If so, thanks, well done, and where's the "fill hole" (assuming it is the drain hole pictured)?
Is this what provides fluid for the viscous?
ChamplainRover
Old 03-15-2008, 03:49 AM   #5 (permalink)
Sorry... wrong Kevin. Just happened to remember that page when I read your post.
That's the fill plug in the picture. The drain plug, according to the SM, is at the 6 o'clock position. In the picture it is almost visible behind the breaker bar.
Just in case...
Kevin
88 RRC "Audrey"
I got some stuff to change the fluid in my power steering and ACE systems Grid_Lock Discovery Series II 0 11-22-2007 01:26 AM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
Transmission fluid change theories Disco Truck Discovery Series I 3 03-09-2007 05:11 AM
PS Fluid Change wimp Discovery Series II 3 03-07-2007 12:30 PM
Brake fluid change wimp Discovery Series II 5 03-02-2007 03:46 AM
