» Sponsors
» Sponsors
Old 01-05-2009, 12:44 PM   #1 (permalink)
Roverholic
lsawicki's Avatar
Gallery: 9
Default Fluids to change at 150k
I think it's time I change the fluids in my RRC
I got it at 142K and other than regular oil changes, I don't think it's had anything changed since 100k.
What are the most important fluids I will want to change?
Here are the ones I have on my list
Oil (bout that time)
Transmission Fluid
CV/Swivel ball grease
Transfer Case
Differential
Any other areas to look at, and which fluids do you guys recommend I use for all of the above?
1993 Range Rover County LWB - Beluga Black
lsawicki is offline   Reply With Quote
Old 01-05-2009, 01:18 PM   #2 (permalink)
Range Rover Freedom Fighter
BullDogSix's Avatar
Gallery: 7
I'd add Brake and Radiator fluids to those as well. How's your fuel filter?
SI VIS PACEM, PARA BELLUM
"If you seek peace, prepare for war"
1994 RRC LWB, Cocked, Locked and ready to Rock!
BullDogSix is offline   Reply With Quote
Old 01-05-2009, 01:24 PM   #3 (permalink)
Roverholic
lsawicki's Avatar
Gallery: 9
It was changed less than 1k ago, along with the fuel pump
Old 01-05-2009, 03:10 PM   #4 (permalink)
Deployed OIF
ArmyRover's Avatar
on top of the brake fluid and coolant I would add the often forgotten power steering fluid.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 01-05-2009, 03:24 PM   #5 (permalink)
Roverholic
lsawicki's Avatar
Gallery: 9
Army, my steering box has a slight leak (nothing new), so I've been using Lucas Power Steering stop leak as a replacement, topping it off when necessary. Great stuff though.
Have you guys used lucas transmission additive?
Old 01-05-2009, 03:36 PM   #6 (permalink)
Deployed OIF
ArmyRover's Avatar
I have in the past but the transmission I threw it in should not be used as a case study it was way to far gone at the time of application. My father has been using it to nurse a aod-e in a mustang gt along and has been happy with the results.
89 Jaguar XJ6
Transmission fluid change theories Disco Truck Discovery Series I 3 03-09-2007 06:11 AM
Sex Change? kellijo The Lounge 39 06-01-2006 12:14 PM
Oil Change Funrover The Lounge 2 03-25-2006 04:32 PM
guys lets talk about fluids...... mr.rover Range Rover P38, Mk III and Range Rover Sport 5 10-26-2004 06:51 PM
What are the equilivent fluids for a NAS Disco 1? Adam in NYC USA Discovery Series I 4 10-07-2004 09:10 PM
