Old 11-17-2004, 01:50 PM   #1 (permalink)
Landy-Andy's Avatar
Exclamation Four new belts for my engine...
Hello,
The time has come to change my belts on my 1991 RR classic!
I have purchased the 4 belts & the task looks fairly straight forward!
Just wondering has anyone out there done this before, have any tips.
What is the recommended way of checking the correct tension on the belts after installed?
All tips, thoughts are welcome,
thanks,
Andy
Landy-Andy is offline   Reply With Quote
Old 11-17-2004, 02:27 PM   #2 (permalink)
lowecolinuk's Avatar
Default Four new belts for my engine...
As a rule you should see 4-6 mm play up/down motion between pulleys on each belt.
regards
Colin
RR 1982 Classic
RR 1993 Classic Vogue SE
Jaguar XJ40 1990
lowecolinuk is offline   Reply With Quote
Old 11-17-2004, 03:32 PM   #3 (permalink)
they are k to do as long as u know wat u are doing.
mathew is offline   Reply With Quote
Old 11-18-2004, 12:22 PM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
It's pretty easy. You'll do fine.
Can't think of any tips except becareful what you pry against when you are getting leverage for the tightening of the belts.
I punch my clown daily.
