Old 07-25-2005, 02:07 PM   #1 (permalink)
Default Front Transfer Case
Well, I was having little buzzin feel and sound around 59-63MPH and found out malfunction front transfer case. Worst thing is, it is not covered under warranty.
So, I assume there are two transfer cases on Classic 95 RR LWB? What could cause the transfer case to go bad?
AdrianL is offline   Reply With Quote
Old 07-25-2005, 02:09 PM   #2 (permalink)
AdrianS's Avatar
One gear box, one transfer case & two driveshafts.
Adrian Strata
www.4x4ag.com
98 DI
34x10.50 Simex JT
2.5" SR lift
Evo Kit
91 RRC parting out
AdrianS is offline   Reply With Quote
Old 07-26-2005, 07:57 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
And two axles.
I punch my clown daily.
Old 07-26-2005, 07:58 AM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
Age, mileage, low fluid....ummmmm abuse.
Lots of things cause them to fail.
I hope mine never does.
Old 07-26-2005, 02:17 PM   #5 (permalink)
Default Transfer case
Well, it is 95, 79k miles, fluid level is perfect, ummm no abuse. No off roading, owned by one lady owner before me.
Like what? My mechanic is puzzled since he does not see the front ones going bad.
Old 07-26-2005, 10:34 PM   #6 (permalink)
AdrianS's Avatar
Did you check the front drive shaft u-joints? It couldn't hurt to remove it and then see if the noise goes away.
Adrian Strata
www.4x4ag.com
98 DI
34x10.50 Simex JT
2.5" SR lift
Evo Kit
91 RRC parting out
Old 07-27-2005, 06:50 AM   #7 (permalink)
sven's Avatar
Front ones? Are you talking about the transfer case or differential?
Old 07-27-2005, 09:51 AM   #8 (permalink)
OkieRover's Avatar
Gallery: 2
I'm still a little confused at what has failed.
