Fuel Flap Fuse.....
This is an annoying remedy that I have with the truck since before the T-Case blew, the fuel flap/Air Conditioning fuse keeps blowing, but it doesn't blow when I push the button for the fuel flap. Now I notice that the fuse has several circuits running to it. It is not only a circuit breaker for the A/C and the fuel flap, but also the blower motor. However the fuse seems to blow even when none of the above circuits is used, like I don't use the blower motor, A/C, and when not needed at the time, the fuel flap.
Does anyone else have this happen to them before? And would anyone have any idea what a common repair would be for this? I know that their would be a short, or high resistance some where in any of these circuits, right now, I would like to have grounds on where to start if anyone has an idea.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
