Old 09-16-2006, 08:58 AM   #1 (permalink)
Question fuel pressure guage
I'm finally getting around to installing new fuel lines and want to install a pressure guage also. Is there any reason not to install it in the engine bay??? I was planning on putting it between the feed line and the fuel rail.
Thanks!
Kevin
88 RRC "Audrey"
Old 09-16-2006, 10:12 AM   #2 (permalink)
My only thought is that this is one real big scourse for a leak in the future.
Fuel pressure is not some we ever check and that being the case, why not set up your fuel system so you can hook a guage to the lines when there is a problem.
Old 09-16-2006, 10:25 AM   #3 (permalink)
Thanks Mike! That was what I was thinking also, that's why I asked.
Would the best place still be between the feed line & the fuel rail? The shop manual says to check it just after the filter. Or is there a third better place???
Kevin
88 RRC "Audrey"
Old 09-16-2006, 06:09 PM   #4 (permalink)
gordo's Avatar
In line before the filter is easier to get to. I bought a nicer fuel pressure tester with the valve type fitting and it had the fittings to bolt into the rover without any mods. In fact I always end up leaving the fittings in whichever rover Ive most recently tested and then take it out next time I get the fuel filter! Not sure if the early ones are different though. Works in my 89 and 92 RRC. Gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
