Old 06-22-2008, 12:37 PM   #1 (permalink)
yieldsign2's Avatar
Default Fuel Pump Polarity?
Well, odd question here...
I am not using the factory plugs for the fuel pump, I had a problem with them once and cut them off and used regular blade connectors.
I've had the truck apart for a couple years, and unplugged the fuel pump and now forget which plug is which (bright I know). Does it matter which way the pump is plugged in, or is there any way to tell? Is the best way to pull a fuel line at the engine and see which way fuel comes out? It seems like it makes noise eitehr way, but the truck isnt starting so I want ot make sure the fuel is right.
Devon Yablonski
1989 Range Rover Classic - Running and Muddy
1988 Range Rover Classic - Parts
http://ads.auctionads.com/pagead/lin...assZyieldsign2
yieldsign2 is offline   Reply With Quote
HELP!! Fuel Pump??? Truck still on trail. bluemax09 Discovery Series I 14 02-22-2006 03:40 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Fuel pump/ Fuel tank issue. Militant-Grunt Discovery Series I 9 12-07-2005 08:54 PM
No start, No power to fuel pump, ECU? Tiderover General Land Rover Discussion 2 09-17-2005 02:24 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 0 11-24-2004 12:42 AM
