Old 04-20-2006, 07:38 AM   #1 (permalink)
Default Fuel Tank recall- Size (gal) ?
I had the recall done on my Classic.
I just bought it not too long ago and seem to remeber filling up to nearly 20 gallons.
Now I only fill up to 15 gallons.
Anyone else have this problem?
I think they migh have given me a smaller tank?!
c93werdna is offline   Reply With Quote
Old 04-20-2006, 09:27 AM   #2 (permalink)
daway's Avatar
i know that my '93 LWB has a 21 gallon tank. i have read of people putting in 40 gallon tanks for long trips (down under Aust). i don't think they would put in a 15 gallon tank. u can ask the place what size they put in or look on your paper work they gave u. another thing u could do is fill the tank up, set the tac at 0 mile and run it down to the red, they refill and divide the mile u went w/ how many gallons u had to refill the tank.
Old 04-26-2006, 09:02 PM   #3 (permalink)
At the pump it says 15 gallons is full!
I got shorted on my tank!
Old 04-26-2006, 10:01 PM   #4 (permalink)
yieldsign2's Avatar
it could be a problem with your fuel level sender, and it just really isn't empty when it is reading empty.
Devon Yablonski
1989 Range Rover Classic - Running and Muddy
1988 Range Rover Classic - Parts
http://ads.auctionads.com/pagead/lin...assZyieldsign2
yieldsign2 is offline   Reply With Quote
Old 04-27-2006, 06:06 AM   #5 (permalink)
Just call the dealer and verify what was supposed to be installed and give the parts dept. the part # of your work order and have them tell you the size of the installed tank.
Too Simple!!
Old 04-28-2006, 08:54 PM   #6 (permalink)
I think you're right about not being empty. Ive been trying to avoid the seeing the Empty Light on so iI fill up Just as soon as I see it flicker and go away.... at tha point I get 15.something gallons, I bet the reserve is about 4 or so gallons...
thanks!
Old 04-28-2006, 09:03 PM   #7 (permalink)
RageRover's Avatar
Well I will say one time, I managed to get about 45 miles or more, out of the tank, after the E light on the gauge came on, and still enough gas to make it to the gas station. So I had around 3-4 gallons left in the tank, if my math does me right. And I know my gauge works properly, cause I calculate the mileage and the amount, and it shows acurate readings with what I calculated.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 04-28-2006, 10:43 PM   #8 (permalink)
smileyq's Avatar
On my disco the reserve is exactly 4 gallons. When my light comes on and I go to the dreaded gas station I pump in almost exactly 21 g. everytime depending on how far I went on the light.
"Good saddles ain't cheap, and cheap saddles ain't good."
smileyq is offline   Reply With Quote
Old 04-28-2006, 11:42 PM   #9 (permalink)
appstatedisco's Avatar
I'm on a college budget, I see the yellow light quite often, unfortunatly, too often. I rationalize this by telling myself it's only cleaning out the tank.
AHO Rugby, a drinking club with a rugby problem.
www.ahorugby.net
"My experience through life has convinced me that, while moderation and temperance in all things are commendable and beneficial, abstinence from spirituous liquors is the best safeguard of morals and health."
- Robert E. Lee
appstatedisco is offline   Reply With Quote
