Old 10-10-2004, 04:24 PM   #1 (permalink)
Default funny 3.5 efi idling
Hi
when the car is cold the engine fires up and idles fine at about 800rpm when hot the same when in between it hunts up and down from 800-0 and cuts out or just keeps hunting if i pull off and drive it is fine.
It has a new engine and all mixture is ok. local dealer cant see what it could be as it is this intermittent. everything seems ok any ideas? everything has been cleaned and or checked
many thanks
simon285 is offline   Reply With Quote
Old 10-11-2004, 02:54 PM   #2 (permalink)
Check to see if you have any vacuum leaks cracked or disconnected hoses)and clean stepper motor where valve seats. good luck.
lonestarrover is offline   Reply With Quote
