92 RR county
Hi guys/gals can someone shed some light on this problem... Air cond, radio, interior light, driver side seat adjustors, horn, sunroof all stopped working at the same time. I've checked every fuse in the book... A-C on the front dash, E1-E7 under the pax seat. Nothing is blown. Are there any relays or fuses in the engine compt that I could check? I can't find any. pls help me stop sweating my arse off.... ![]() |
4x4 Adventure Gear
Check grounds (one behind battery, one behind DS cylinder head, there are a few others but I can't remember where right now). Also check the fusible links, the fail and cause some electrical problems.
Good luck.
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
All of those things are accessories.
Most often you will find that the back of you ignition switch is coming loose. Check that out and with your hand get the back of the switch seated better. Check those systems and see if it doesn't fix it. I used a zip tie to hold mine back in place and it's been working for me for nearly 4 years. |
Open the bonnet and look between the battery and inner right fender. You'll see a mesh wrapped bundle coming off the battery. It is one of the two Positive cables. Inside that mesh wrapping are nine fusible links.
