Old 10-16-2005, 10:51 PM   #1 (permalink)
Rocky Mountain High
Funrover's Avatar
Default Gear Ratio
What are the gear ratio's and axles offered in 91 -92 on the RRC? what was most common?
Old 10-17-2005, 01:22 AM   #2 (permalink)
I think all US Range Rovers are 3.54:1 and, if I'm not mistaken all the axles are 10 spline until halfway through 1993. As an alernative, 4.11:1 is a popular ratio when you go with bigger (33" and over) tires.
Old 10-17-2005, 03:17 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
When did the 24 spline come out?
Old 10-17-2005, 04:13 PM   #4 (permalink)
I believe it was half way through the model year Range Rovers got 24 spline axles. I don't know what the VIN is that indicated the change.
Old 10-18-2005, 02:25 PM   #5 (permalink)
troverman's Avatar
All Classics US are 3.54:1; all P38a's (4.0/6) also use this ratio. Classics 1993+ and P38's 1995-1998 use 10-spline in the front and 24 spline in the rear. The reason is vehicles equipped with traction control got the heavier duty axles. The Classic got it in 1993, the early P38a's had rear traction control only until 1999. In '99 all Range Rovers and Disco II's got 24-spline axles all around (4-wheel ETC) All Disco 1's have f/r 10-spline and the usual final drive ratio. Not a bad ratio.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 10-18-2005, 02:52 PM   #6 (permalink)
Rocky Mountain High
Funrover's Avatar
thanks for the info... I am looking to build my rig a bit more sturdy... I have plans to build up a 4.6(lucky for me my neighbor owns a speed shop and works hand-and-hand with the local rover shop, non-dealer), put in a Lt230, 24 spline axles..... I would like to get a little better gear ratio though.. Guess I have my work cut out... .Thanks again
