Old 03-26-2005, 09:14 AM   #1 (permalink)
LRO Founder
Serg's Avatar
Default Hard brake pedal..
Ok, so my 1995 Classic has a hard brake pedal. Ever since I bought it I noticed the pedal was a bit harder than it should be. I had new pads slapped on the old rotors about 4 months ago. About 3 weeks ago the brake light came on the dash and has not gone off. I notice that the brake pedal is hard. Almost as if it had no power brakes..
I checked the vacuum lines (those that I could find) and all seem ok. I wonder if it is the brake booster or??? Any ideas?
Serg
Current Vehicles:
2003 BMW 540iT M Sport
2005 BMW R1200GS
2004 Element Skateboard (Indy trucks, Bones Swiss, etc...)
Past LR's:
1995 Range Rover LWB Classic
1997 Discovery XD
1995 Range Rover LWB Classic 4.0
Serg is offline   Reply With Quote
Old 03-26-2005, 09:59 AM   #2 (permalink)
TerryS's Avatar
Sure sounds like your ABS pump is, if not already, packing it in. Can you hear it run when your turn your ignition on? Does it sound like it always did, or does it have a raspy whine to it? If it's working properly, you will hear it begin to slow down just before it shuts off.
Old 03-26-2005, 06:54 PM   #3 (permalink)
Terry sems to be on the right track. When you start the RR the ABS pump should turn on for awhile then turn off until you apply the brake about 6-7 times, then turn on again to prime the system. Your ABS pump is probably weak. On the Atlanic British web site in the Tech section it shows how to test your ABS Check the ABS relay, maybe pump isn't turning on.
http://www.roverparts.com/techtips_main.html#rangerover
lonestarrover is offline   Reply With Quote
Old 03-27-2005, 09:03 PM   #4 (permalink)
LRO Founder
Serg's Avatar
Yeah I can hear it run when I start the Rover, and then it turns off.. will have to check that page and see what I can troubleshoot.
Serg
Current Vehicles:
2005 BMW R1200GS
Past LR's:
1997 Discovery XD
