Just finished installing new calipers, pads, & rotors (non-ABS). After bleeding brakes twice, the pedal feels hard with just a short movement. I will bleed them again to make sure there's no air stuck. Does air make a hard or soft pedal? Vacuum leaks cause soft pedal too right?
When I was changing out the calipers, the brake fluid dropped extremely low in the reservoir. Could that have done something to the master cylinder or servo?
Kevin 88 RRC "Audrey" |
Rebuilding Rover
Air in the lines in my experience makes for a very soft squishy brake pedal.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
If I am not mistaken RRC brakes are supposed to be firmer. They are not vacuum assisted but pressurized by pump.
Abraham 1993 Range Rover Classic LWB 1995 Range Rover Classic LWB ![]() I run, play, fix and live Rovers because I choose to. |
Kevin's truck is non ABS, he has no pump. If it were an ABS truck it would point to bad accumulator, diaphragm gone, no nitrogen cusion. Very hard pedal in a non ABS truck makes me think servo isn't functioning. Short travel may be just that you have new pads and clearance to disc is minimum (which is OK)
#5 (permalink) | |
The pedal feels a lot better now. Initially I could not hear not hear the servo but it seems to be working. Also feels better with a higher RPM. I think the new Insky cam creates less vacuum at idle ![]()
That's probably more perception than reality. Your highest vacuum will be when the throttle plate is closed, especially coming off a high rev, but close even at standing idle. Check the connections at the servo, the rubber grommet on the servo, and the connection on the righthand side of your plenum base plate. Look the hose over for cracks. If you're still suspicious of a vacuum leak, get some carb cleaner and spray all the connections and along the hose, with the engine running. If you detect an increase in rpm, there's your leak.
| Thread Tools | |
| Display Modes | |
| wheel cylinder rebuilding | theclay | Series Land Rovers | 23 | 05-21-2007 04:45 PM |
| Brake Pedal...weird vibrations when pushed | boxer | Range Rover Classic | 1 | 12-29-2006 04:45 AM |
| How hard to swap out the Brake Light switch? | Adam in NYC USA | Discovery Series I | 2 | 01-31-2006 04:58 AM |
| Long Brake Pedal Syndrome? | PCrover | Discovery Series II | 21 | 06-29-2005 10:12 AM |
| Hard brake pedal.. | Serg | Range Rover Classic | 3 | 03-27-2005 09:03 PM |
