Links
Old 05-06-2008, 10:59 AM   #1 (permalink)
Default head bolt count
Just ordered the head gasket kit with head bolts. Each head has 14 bolts. The replacement kit comes with 10 bolts ber side- was told this was a service update by LandRover. Are you leaving 4 lower holes empty on a head gasket job?
Thanks,
Rob
rturbett is offline   Reply With Quote
Old 05-06-2008, 11:05 AM   #2 (permalink)
Elemental's Avatar
Yes. It works just nifty.
Old 05-06-2008, 11:06 AM   #3 (permalink)
sven's Avatar
Thats right.
99 D1
73 Series SWB
95 RRC LWB - Sold
Old 05-06-2008, 01:00 PM   #4 (permalink)
OkieRover's Avatar
Gallery: 2
The additional 4 bolts actually torque the head TOO MUCH on that side and was probably why the original head gaskets didn't last as long as they should have. The new gaskets you get will actually have those holes covered by gasket material so you won't even be able to put bolts in those holes.
I punch my clown daily.
Old 05-08-2008, 05:59 AM   #5 (permalink)
Thanks for the reassurance. I would hate to have put it back together and then have someone say- "why didn't you drill holes in the gasket?"
Rob
#10 Head Bolt torque sunshineking Discovery Series I 27 03-14-2008 09:16 PM
Valve cover bolt head size? krigsmakten Discovery Series II 2 12-07-2007 09:07 PM
URGENT--Stripped head bolt kkrover Range Rover Classic 6 01-19-2007 09:50 AM
head gasket/possible cracked head jdsmith46 Discovery Series I 7 01-02-2006 12:22 PM
Cylinder head removal w1jhs Series Land Rovers 6 09-29-2005 12:33 PM
