Old 06-09-2007, 12:25 PM   #1 (permalink)
Where is my Black Son?
Default head compatability
Will heads from a 4L 97 disco1 work on the block of a 1990 RRC 3.9?
One has 8 bolts one 12
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler.
1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
MuddyRangeRover is offline   Reply With Quote
Old 06-09-2007, 03:45 PM   #2 (permalink)
rqsall's Avatar
It will fit as far as I know. But I'm pretty sure the disco has 10 bolts and the range rover 14. You can omit the outer row of bolts without problems, and you should replace the metal gasket with a composite one.
rqsall is offline   Reply With Quote
Old 06-09-2007, 04:26 PM   #3 (permalink)
You can use the heads off the Disco but make sure you use the composite gasket and you absolutely must get new head bolts. Call Rovers North and they'll set you up with everything you need.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 06-10-2007, 07:31 AM   #4 (permalink)
thankgs guys. Yes I meant 10 bolts.
By composite gasket you mean the brown material type?
Old 06-10-2007, 06:46 PM   #5 (permalink)
Ian Matthews
p76rangie's Avatar
You only need to replace the bolts if the use once type bolts have been used previously. Rather than replace them with the same bolts, you are a lot better off changing to studs.
p76rangie is online now   Reply With Quote
Old 06-11-2007, 04:47 PM   #6 (permalink)
New head bolts are cheap insurance, just change them anyway. You can not tell how many times they have been torqued or over torqued before just by looking at them. Head studs have a more even rate of stretch, thus a more even clampload and are alot stonger. Head studs are only realy required on high compression engines (like race engines). Having said that, if it was me I would upgrade to the studs. Not a fantastic price difference and why not make it better than it was since you have the heads off anyway.
roverandom is offline   Reply With Quote
Old 06-12-2007, 03:13 AM   #7 (permalink)
Ian Matthews
p76rangie's Avatar
Using studs on Rover motors reduces the risk of blowing a head gasket and rear coolant leak.
