Old 05-03-2008, 12:35 PM   #1 (permalink)
Smile head gasket project
1990 Rnge rover classic- 67,000 miles on it.
Diving in to the biggest engine project for me yet.. Can anyone offer some advice as I go along?
Was told I coud do the head gaskets without removing the engine. Would you leave the exhaust manifolds on and take them off with the heads, or would you try removing the 8 bolts per side?
Power steering pump removal is not as obvious as the ac compressor. Do you have to remove the distributor to remove the ps pump?
Does anyone have advice on head gasket kits?
Thanks in advance for your help.
Rob
rturbett is offline   Reply With Quote
Old 05-03-2008, 05:16 PM   #2 (permalink)
Took the exhaust manifolds off- not as difficult as I thought it might be. Found one broken lug, a couple of loose ones as well. Good thing the "keepers" were used. Now to attack the power steering pump.
Old 05-04-2008, 04:54 PM   #3 (permalink)
Power steering pump ends up being very simple if you take the pully off! Duh!
anyone have a favorite way to remove the buildup and tarnish in the valve covers and rocker arms?
Old 05-04-2008, 04:57 PM   #4 (permalink)
Rebuilding Rover
ArmyRover's Avatar
gasoline and a stiff bristled brush.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-04-2008, 06:44 PM   #5 (permalink)
Happy with the project so far- We'll take the heads off tomorrow. Any hints on how to find a good machine shop to suface the heads? I'm hoping my repair shop will guide me, though they may not be happy they are getting the gasket job.
Rob
Head Gasket Change PeteRice Discovery Series II 6 04-07-2008 01:27 PM
Exhaust Leak = Head Gasket + Warped Head ealex Discovery Series II 1 05-23-2007 01:29 PM
Replacing head gasket questions rqsall Range Rover Classic 7 01-19-2007 05:12 PM
K Series head gasket problem dearot Freelander / LR2 14 10-07-2005 03:20 AM
K Series head gasket procedure freelanderman Freelander / LR2 5 04-20-2005 10:53 AM
