» Sponsors
» Sponsors
Old 10-15-2009, 02:05 PM   #1 (permalink)
Default Headlight switch integral lighting
I have a 2000 Range Rover 4.6 HSE.Just bought this vehicle and have a couple of questions re the main lighting switch. 1/ Does the switch have integral lighting so the switch is visible at night?
2/ Is it possible to relamp the switch if the light is not working or do I have to replace the switch completely?
Any idea what the lamp would be?
Thanks for any help.
bunghole is offline   Reply With Quote
Old 10-17-2009, 11:10 AM   #2 (permalink)
hermanpj's Avatar
Gallery: 4
you should post this on the appropriate board. this forum is for classics, which were made through 95. I had a 2006 4.6, i do believe that switch is supposed to be illuminated, but i dont have the truck anymore so cant be sure. posting it on the other forum, you'll get the attention of guys who are living with these trucks today. if it is illuminated, yes you can replace the bulb without replacing the switch. You should also obtain the RAVE CD which includes exploded diagrams and basic repair routines for this sort of thing. its a great help, i probably use it once a month at least.
Pat Herman
Old 10-17-2009, 06:45 PM   #3 (permalink)
Yeah Thanks I screwed up and put it here. No harm done though is there?
Old 10-19-2009, 08:21 AM   #4 (permalink)
hermanpj's Avatar
Gallery: 4
it happens fairly often actually. its not completely obvious where to post for generation II range rover. i'm sure those guys will help you sort it out directly. good luck!
Pat Herman
Headlight switch OldnDirty Range Rover Classic 1 02-16-2009 03:32 PM
Headlight Switch justmealex Discovery Series II 2 02-08-2007 08:14 PM
Kill Switch re-wire monkey catcher Defender 2 10-28-2005 08:54 AM
Ahhh! Careful removing steering wheel! (WTB headlight/Rwiper switch) yieldsign2 Range Rover Classic 2 05-24-2005 05:04 AM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 10:06 PM
