Old 10-26-2005, 03:50 PM   #1 (permalink)
Question Headliner repair-Flocking or soft touch paint?
Now the beast is up and running (a broken brand new lifter was the problem....bottom part sheared clean off by the new cam) I am trying to tidy up some other parts of the car.
The saggy healiner has been stapled into position by mad previous owner. While funtional it does not look great.
I was thinking of removing the old foamed backed trim, rubbing back the hardboard surface to get the old glue off and 'flocking' it with a kit from someone like Frost's or even using another 'soft touch' paint.
The car is in semi retirement and a long way from being a concours candidate, so I do not mind going away form the factory fitting which was dire like any 1980's Rover product....
Has anyone tried this solution or even tried simply glueing a non foam vinyl material?
philippe is offline   Reply With Quote
Old 10-26-2005, 04:13 PM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
I talk about repairing the headliner on my website. It's not hard to put fabric back up there.
What I have learned from having the liner out and driving around is it absorbs a huge amount of noise. So consider this when you are putting whatever you want back in.
I punch my clown daily.
Old 10-26-2005, 05:19 PM   #3 (permalink)
4x4 Adventure Gear
John C's Avatar
I used garage floor paint (white). I used up a whole gallon, probably 5 or 6 coats. Came out pretty good.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 10-27-2005, 04:15 AM   #4 (permalink)
I used double sided sticky tape (didnt work), staples (some came out - looks a right mess). I've now given up and it sits on my head like a shroud !
champ69 is offline   Reply With Quote
