Old 01-05-2005, 04:46 AM   #1 (permalink)
01Rover's Avatar
Default heated seats
I have an 01 Range Rover and my heated seats dont work. Anyone have any ideas what might be the problem?
2001 Range Rover, just got it so I have not had a chance to mod it yet.
01Rover is offline   Reply With Quote
Old 01-05-2005, 07:33 AM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
Could be a couple things.
Make sure they are plugged in first. If anyone worked on it once and forgot to plug it back in, you may be in luck.
Check those fuses.
Thirdly you may have a bad heater. It is common that a wire gets broken in the seat and the heater no longer works. You will need to replace the heating element, not too much fun, as the seat needs to be removed from the Rover and tore down to repair or live with it.
My driver side doesn't work and I'm just gonna live with it.
I punch my clown daily.
Old 01-05-2005, 08:15 AM   #3 (permalink)
01Rover's Avatar
I think I might live with it. Cause everything is pluged in and tthe fuses are fine. Thanks for the info.
Old 01-05-2005, 10:46 AM   #4 (permalink)
hamrendan's Avatar
Default Why they get broke
They usually break if you put your knee on the seat to support your wieght, like if you are trying to get something in the back. Yes they are a pain to fix and can be expensive too!.. I find a nice set of sheepskin seat covers from costco keep the seats warm in the winter and cool in the summer..
HTH
Dan Hamren
93 LWB "Dubya" AKA "The Beast"
hamrendan is offline   Reply With Quote
