Old 01-03-2008, 09:28 AM   #1 (permalink)
Default Heated Seats - '95 LWB
Now that the wife is using the RR as her daily driver, she'd like the heated seats to toast her buns as she drives... Both seats don't warm up.
The switches light up so power is getting that far, fuses in the panel are good. I've read about taking the seat apart to replace the pads but only found references to the Disco or later style seats.
Are there common fault points outside of replacing the element itself?
Seems like removing the seat itself is pretty easy (4 allen bolts) but is it necessary to separate the lower cushion from the top? (I suspect it's usually the lower pad that fails, not the top one, correct?)
What's a good source for the heater elements?
Thanks!
'95 RRC LWB, '05 Suburban Z71 (not stock), '94 F350 (only the cab shell & rear bumper is original), '62 International 404 tractor (red & white) & many other project cars in the past!
57loboy is offline   Reply With Quote
Old 01-03-2008, 05:32 PM   #2 (permalink)
A buddy of mine and I did a quick fix following the below link. took us 10 per 1995 classic. works great.
Heated Seats Quick/Easy Fix!
1995 SWB Classic
1997 M3
2006 Prius
2000 TDI Golf
1995classic67 is offline   Reply With Quote
Old 01-22-2008, 11:17 PM   #3 (permalink)
vince80's Avatar
I did this today, and it turned out great!!! The only thing is, you have to turn it off once it gets to your desired temp.
vince80 is offline   Reply With Quote
Old 01-23-2008, 07:50 PM   #4 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
Thumbs up
Hi there
I also own a...uhmm....(whisper) Jeep Wrangler...so I get the 4wd Hardware catalog (Jeep stuff). In said catalog are some universal seat heaters for $99...check em out. WarmSeats™ Carbon Fiber Seat Heater and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
This is what I'm going to do.
BullDogSix is offline   Reply With Quote
Heated seats: bypassed lower cushion ...... HaroldC Range Rover Classic 6 12-17-2007 08:41 AM
Heated Seats Quick/Easy Fix! Sign Guy Range Rover Classic 31 02-05-2007 09:41 AM
Heated Seats hibby Discovery Series II 20 05-21-2006 05:47 PM
Heated Seats finally!! RoverAsh Discovery Series I 11 10-01-2005 12:28 AM
heated seats SUSAN General Land Rover Discussion 1 01-31-2005 09:35 AM
