Old 11-10-2007, 07:13 PM   #1 (permalink)
gragravar's Avatar
Default heater blower moter dead?
alright, I have done some digging and have read lots of issues with the heater blower - mostly letting fresh air in with seals not closing up all the way. While I am having that issue, I am also having another one:
When I turn on the fan for the climate control system, the rover lets out a horrible squeal like a belt is slipping, then the engine dies. any ideas about what this might be? is this one where I should plan a day to take the entire dash apart to get to the heater motor?
current rides:
2004 Land Rover Discovery II SE7 (still stock)
1992 Range Rover Classic (work in Progress)
2003 Audi allroad (more than a little modified)
1999 BMW R1100S
2001 BMW 330i (wife needed something to drive)
gragravar is offline   Reply With Quote
Old 11-10-2007, 07:19 PM   #2 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Sounds like a big short or else your belt is really loose.
Jim Hall
obstacle.” Michael
Old 11-13-2007, 06:41 PM   #3 (permalink)
gragravar's Avatar
well, to get a good picture of what might be wrong, I stopped by JC's rover shop in Denver. just from the description of the squeal, he knew what the problem was then a 5 second look over at the truck confirmed it. problem wasnt the heater motor, but the A/C compressor which had siezed up. since it is belt driven, turning on the fan when the A/C or the defroster setting is used turned on the A/C which wouldnt turn and which caused the belt to squeal then to stall the motor on the car.
so a quick unplug of the compressor turned that functionality off. now my heater works, but I'll need to replace that compressor before I find the need for A/C in the spring.
current rides:
1999 BMW R1100S
