Old 03-20-2006, 01:59 PM   #1 (permalink)
Default Heating redux
Many of you have already helped. Still trying to get a real diagnosis before changing things.
Here it goes:
White smoke out back at start up but goes away in about 1/4 mile hmm condensation but seems like alot. Put hand infront of exhaust after it has stopped, no water or sticky build up--can't really smell anti-freeze smell.
1.Overheats at freeway speed, shoots up quickly
Leads me to think ahhh headgasket/crack somewhere
2. Hmmm oil and coolant bone clean
3. hmm could just be exhaust gases escaping into coolant passage hmmm
4. Did block tester to test for Hydrocarbons in cooling system did several tests and different conditions---nothing hmmmm
Burped coolant 50 times
Tried experiment of bypassing heater core--acutally took longer to overheat and slower--so did change things.
So I thought I had 2 pieces of evidence pointing to head gasket but the hydrocarbon test is supposed to be diffinative?
Just get a new radiator??
Haven't wanted to shoot parts at the problem but my finger is getting itchy cause after new radiator is pulling the heads off just to make sure?
Am I missing a step or troubleshooting point? Maybe water pump but its not weeping and seems to flow---suppose I could have it flow tested. Thermo is new and works. I suppose I could have a hole in the exhaust letting more water in overnight than usual causing the white smoke--but the two together made me really think headgasket.
Any thought?
THanks
Chris
GKChesterton is offline   Reply With Quote
Old 03-20-2006, 02:21 PM   #2 (permalink)
RageRover's Avatar
Checkout your thermostat, and see if any coolant overflowed out of your overflow tank. And a little white was typical for me for a while only because water was trapped in the resonator peice on the tail pipe, after hacking that off, no more white smoke. It is also possible your radiator is clogged, and causing the coolant to evaporate, believe it or not, and you lose coolant throught the overflow. This happened on several Jeeps I worked on, LOL , and the radiator and thermostat were replaced.
Hope this helps!
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 03-21-2006, 07:44 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
Everything you just typed suggests head gasket. Those are the exact things that happened to me. In the end I replaced the head gasket AND the radiator. I got tired of chasing the problems around.
I punch my clown daily.
Old 03-21-2006, 11:14 AM   #4 (permalink)
Ya you evil teller of truth and wisdom. People don't want to hear that kinda thing. .
I ordered a Radiator, as it probably needs to be done anyway. Will put it in and problem will still be there . Just want to drive it a few months till summer when I can do the whole motor. Is there a magic pill for that--they must have one on Ebay? I'll get one that either fixes it, makes me think its fixed, or makes me not care that it isnt fixed.
Old 03-21-2006, 11:32 AM   #5 (permalink)
OkieRover's Avatar
Gallery: 2
Better living through chemistry, I say!!!
