Links
Old 03-22-2005, 05:36 PM   #1 (permalink)
Default HEI Installed!!
This is a Davis Unified Ignition distributor by Performance distributors this thing rocks though i had to modify the distributor hold down with a plasma torch (enlarge it) because the shaft on the new dist. was larger in diameter, and remove the engine pull bracket with a die grinder so the distributor would clear. all it needed was a switch 12v and a tachometer signal all from the old coil wich was no longer needed because it is all built into the cap of the HEI. whats cool though is when you need a cap or rotor just go down to the auto parts store and buy a GM part. Other then that it was very easy install.
Lucasfree is offline   Reply With Quote
Old 03-23-2005, 05:10 AM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
COOL!!!
I had an HEI Dizzy in my CJ7, was great..
I just noticed that you used their wires. So the pre 87 dizzy fits 89 and up??
Thanks for the pics.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 03-23-2005, 07:44 AM   #3 (permalink)
i think it does have another part number
