New issue. I start the truck up in the morning (cold weather) No problem. I drive about a mile to get my cup of Joe. Walk out side get in truck turn key: Ignition, truck cuts out , turn key ignition drive away. Once its warmed up its always a fire/ die , fire. what gives?
What year Rangie? Does it have the Ignition Amplifier relocation kit?
John C
1999 DI - LR HD Springs
1996 DI - parting out
1994 RRC LWB - 3" AG lift
1990 Kawasaki KL650B Tengai - parting out
1989 Kawasaki KLR650
1988 Kawasaki KLR650 - parting out
1979 Puch XK
1980 Puch Magnum MKII
1980 Puch Magnum MKII - parting out
That's right, 95 should have the ign amp by the steering reservoir box or on the DS fender.
Have you done any maintenance on the Rangie (replaced plugs, wires, etc)? How's the fuel filter? Has it been replaced?
More info would help us.
John C
1979 Puch XK
Replaced plugs,wires,etc. I thought of filter, so now that it has been mentioned I will do that. Amazing how many $ can be spent on these rigs. It is a serious addiction.
Off the top of my head I don't know how to check it. I think I have one or two of these amplifiers, I might be able to lend you one to test. Do you ever come into Manhattan?
So when it's warmed up does it shutoff?
Will it restart when it's cold again?
Can you reproduce the symptons everytime?
John C
1979 Puch XK
Once the truck is warm: turn key, it starts up then dies. Turn key starts and runs. It is like clock work every time.
I live in the Hamptons ( bridgehampton ) I try very hard not to cross the shinnecock canal. I used to live on 85th and Columbus. Kind of miss the city though.
There is no real practical way to test the ign amp module for faults. You either identify it by eliminating all other possible causes or swap in a known good unit and verify operation.
Reading more about your problem however I'm not 100% certain that is the problem. Have you looked at the ign switch wiring? They can give symptoms very similar to those you are experiencing.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
So I swapped rotor and cap= 0.. Now it doesn't start. Pulled # 2 plug, and have spark. Truck will not fire up!!!!!!!!! Must have pulled the cap and rotor 10 times. Still big 0
