Old 12-23-2007, 05:09 PM   #1 (permalink)
peterbat's Avatar
Question help!! cannot move lever....
hey i was wondering if this has happened to anyone, my93 classic iam unable to shift lever into low range or into neutral. high range works fine. is this just a linkage issue or worse????? please help a worried owner!
cheers, pete bat
1993 range rover classic county
2006 subaru outback 2.5i
1989 coleman williamsburg pop-up
peterbat is offline   Reply With Quote
Old 12-23-2007, 06:20 PM   #2 (permalink)
seized linkage, for these simptoms the dr. recomends the use of large amounts of lubricant followed by the back and forth movement of the lever until unstuck, once achieved move lever to its different positions at least once a month.
if the lube does not work, surgery may be the only other solution, you either remove the center console and all is things to gain better aproach at the linkage, dissasemble clean and reasemble with anti seize compound, attempt to do the same from under the truck
or have a shop do it for you.
good luck
carlosz is offline   Reply With Quote
Old 12-24-2007, 05:03 AM   #3 (permalink)
peterbat's Avatar
thanx carlosz,
iwill be looking at linkage today, you've put my mind at ease, i was thinking it was a linkage issue-so you've backed me up! now to pull the centre console apart.
Old 12-24-2007, 12:21 PM   #4 (permalink)
it is a good way to kill a day while the family goes bezerk on a christmas spirit.
good luck.
Gear Shift Lever Help! 2rovers Series Land Rovers 8 10-20-2006 10:44 AM
Cant Move?! lucas Defender 5 01-07-2006 03:31 AM
Transfer lever will not move... Nantucket LR Disco Discovery Series I 3 12-13-2005 06:48 PM
