hey i was wondering if this has happened to anyone, my93 classic iam unable to shift lever into low range or into neutral. high range works fine. is this just a linkage issue or worse????? please help a worried owner!cheers, pete bat
location:rhode island, usa 1993 range rover classic county 2006 subaru outback 2.5i 1989 coleman williamsburg pop-up |
seized linkage, for these simptoms the dr. recomends the use of large amounts of lubricant followed by the back and forth movement of the lever until unstuck, once achieved move lever to its different positions at least once a month.
if the lube does not work, surgery may be the only other solution, you either remove the center console and all is things to gain better aproach at the linkage, dissasemble clean and reasemble with anti seize compound, attempt to do the same from under the truck or have a shop do it for you. good luck |
thanx carlosz,
iwill be looking at linkage today, you've put my mind at ease, i was thinking it was a linkage issue-so you've backed me up! now to pull the centre console apart.
| Thread Tools | |
| Display Modes | |
| Gear Shift Lever Help! | 2rovers | Series Land Rovers | 8 | 10-20-2006 11:44 AM |
| Cant Move?! | lucas | Defender | 5 | 01-07-2006 04:31 AM |
| Transfer lever will not move... | Nantucket LR Disco | Discovery Series I | 3 | 12-13-2005 07:48 PM |
