» Sponsors
» Sponsors
Old 07-03-2009, 08:16 PM   #1 (permalink)
Default Help me with my 94 Range Rover!
Hey guys,
So I bought my first Range Rover knowing it needed a head gasket. I took it in to a European Speciality mechanic and they redid the head gasket. Since then they have not been able to get it to stop blowing coolant out of the coolant reservoir. I have taken it back 4 times and it still does the same thing. They have replaced the reservoir tank and cap and re-flushed the entire system.
I only need to drive it about 10km for it to 'pop'. It doesn't seem to overheat according to the gauge, although the engine compartment gets quite warm IE: the pole that holds the hood up is pretty hot to the touch. It also starts to sound really knockey (not a word). I have attached a couple videos and unfortunately the sound on it didn't really come through well. The knocking is much louder in person.
Check the videos out here:
Movies
Any ideas guys?
johnfaires is offline   Reply With Quote
Old 07-04-2009, 09:54 PM   #2 (permalink)
Sounds like they screwed it up big time. They need to open it back up...
bjwhite is offline   Reply With Quote
Old 07-04-2009, 10:25 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
obviously not a head gasket. Did they check for a slipped liner while they had the heads off?
p76rangie is online now   Reply With Quote
Old 07-05-2009, 01:15 PM   #4 (permalink)
Rockclimbing's Avatar
this sounds similar to the problem i had with my MG. Possibly a bad head/heads?
1992 Range Rover Classic County
1973 MG Midget
Rockclimbing is offline   Reply With Quote
Old 07-05-2009, 01:42 PM   #5 (permalink)
slipped liner.....? cant tell from the vid if that was bad enough to be a rod knock but either way it doesn't bode well.
99 Range Rover
Stevelkinevil is offline   Reply With Quote
Old 07-05-2009, 10:42 PM   #6 (permalink)
Well that doesn't sound to promising.
I took a much higher quality video of it. You can really hear the knocking. Check it out here:
MobileMe Gallery
John
P.S. Yah I know, I have a bad strut.
Old 07-06-2009, 07:21 AM   #7 (permalink)
Ian Matthews
p76rangie's Avatar
Rust inside the exhaust pipe is not a good sign
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 21 04-02-2009 10:05 AM
Land Rover unveils Range Rover Autobiography for British show Administrator Land Rover News 2 09-29-2008 06:25 AM
2007 LR Range Rover review torres Range Rover P38, Mk III and Range Rover Sport 0 04-25-2007 12:56 PM
Range Rover vs. Disco nmtdriver General Land Rover Discussion 5 01-28-2005 10:15 PM
RamAir Air Filter for Land Rover Discovery 1 95 Range Rover Classic $25.00 hamrendan Land Rover Parts and Accessories 0 01-24-2005 09:08 AM
