I recently replaced the head gaskets on my 3.9. It was sitting for 3 months apart before I was done (out of town for work). Well finally done, motor seems to run strong (except the fact I need to play with the timing and idle). When driving it the trans isn't shifting properly.
Say I floormat it the motor revs high and truck barley moves, let off throttle and trans will shift What should I look for? I changed the trans fluid last year and put on 1200 miles before starting the heads. Trans was perfect before messing with the motor. Is there any thing I could have done well replacing the gaskets??? |
Hi,
Was it just the heads that you took apart? Did you open up the transmission when changing the fluid (to access the filter)? It sound a bit like the symptons that a friend had when his torque converter packed up! But, before I get you too worried.... Did you check the transmission dip stick with the truck level, in neutral & warm? (any of these not followed can give you a false reading on the dipstick) & the incorrect level in the transmission. Also, you say that you changed the transmission fluid a while ago...is there any way you may of overfilled it above the line on the dipstick??? If you did overfill, this could cause problems! Good luck, Andy |
#3 (permalink) | |
I then did the head gaskets and didn't go near the trans Can a trans develop a problem from sitting three (3) months? ![]() |
So you have poor throttle response and the trans is shifting weird? My truck sat for a year and the fuel injector rail got clogged up from rust. It had no throttle response (couldnt go over 50mph) and the trans shifted really weird. As soon as I figured out the fuel problem, the truck drove and shifted properly. So I'm guess ing that its engine related.
#5 (permalink) | |
Injectors are new same time as the trans fluid change... so they also have 1200+ miles on them and the motor rev's strong in neutral (for lack of a better term...like a raped ape) I'll be checking everything I can over the next few days Thanks for the reply Keep the advice coming guys even if it's not a direct fix it's still a double check |
#7 (permalink) | |
No, and for future aaaaahhhhhh never mind I don't want to hijack my own thread I may have the solution there is a cable from the throttle assembly to the trans that may be kinked or hung up... it will have to wait till tomorrow night aaaaaahhhhhhhhh ![]() |
