Old 02-04-2008, 12:43 PM   #1 (permalink)
ChamplianRover
Default Help Removing Front Cover
I need help with the following.
1. I've removed the oil pan, but how do I now get it out? No matter which way I turn it, sway bars etc. are in the way!
2. I need to lock the transmission so I can turn the bolt on the front of the crankshaft pulley. I've been told there is a service plate over the transmission that will let me grab the drive shaft to keep it from turning while I undo the bolt. What does this service plate look like (shape, size) and where located?
Thanks,
Champlain Rover
ChamplainRover is offline   Reply With Quote
Old 02-04-2008, 01:10 PM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
Round, with three bolts if I remember correctly.
I punch my clown daily.
Old 02-04-2008, 04:56 PM   #3 (permalink)
ChamplianRover
Thanks, Okie.
How about the oil sump pan? How da heack do I get this thing out?
ChampRover
Old 02-04-2008, 06:50 PM   #4 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
I've only had my 94 for a couple of days now so I have no "hands on" rover experience...but on other solid axle 4x4 vehicles I've worked on I have found it helpful to jack up the vehicle on the frame so that the front axle droops down giving more clearance.
BullDogSix is offline   Reply With Quote
Old 02-05-2008, 03:07 AM   #5 (permalink)
rqsall's Avatar
If you have an EAS truck, you can put it at its highest setting, drop the oil pan, rest it on the sway bar, then remove the pickup pipe/screen from the sump (two small bolts, some fancy wrist work required here.). Then you can slide the pan over the front axle. On a non-EAS truck, you'll have to jack up the car on the chassis beams so the axle drops really low.
HTH.
1991 RRC 3.9 EFI
manual gearbox (LT77)
rqsall is offline   Reply With Quote
New Front Cover / Oil Pump / Timing Cover for 4.6 cap-pig Land Rover Parts and Accessories 0 11-11-2007 04:31 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Removing the front bumper side covers on my '03 disco entropy Discovery Series II 2 11-17-2005 04:15 PM
Cracked Front Differential Cover Roving Westward Range Rover Classic 5 09-22-2004 07:00 AM
