Old 08-01-2006, 05:48 PM   #1 (permalink)
Tropical Beach Bum
lucky's Avatar
Question Horn 93 lwb
yesterday i was honking the horn and my fuse blew . i changed the fuse and then pressed the horn and it blew again . where would you start looking?? any one
lucky is offline   Reply With Quote
Old 08-01-2006, 07:54 PM   #2 (permalink)
RageRover's Avatar
Does the truck have an alarm system that blows the horns when it goes off?
I would start there, or look at the wires and connections for corrosion. Resistance in a circuit is grounds for a blown fuse.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 08-02-2006, 11:29 AM   #3 (permalink)
LANDY96's Avatar
Uhh my horn sounds sick.... like it needs a boost! When the alarm goes off, it sounds even worse... Do you think my horn just needs to be replaced or just clean up some connections?
Thanks!
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 08-02-2006, 12:27 PM   #4 (permalink)
daway's Avatar
Thanks!
try the contact spray (radio shack) and or clean 1st. then go w/ a new horn if it does not work.
1993 RRC, county LWB "bertha"
myroverworld
Old 08-02-2006, 04:42 PM   #5 (permalink)
Tropical Beach Bum
lucky's Avatar
thanks guys , and i do have an alarm. sounds like my wires are crossed
