Old 11-28-2007, 11:13 PM   #1 (permalink)
sgnden's Avatar
Default How to Open Upper Tailgate?
Hey...
The handle mechanism has fallen-off the upper tailgate of my '92 RRC.
There is now just the hole...and I can see a small "forked" piece in there...but it does not offer any resistance...just floats around.
What method can I use to open it?
I found a used replacement....I suppose I could just detach it at the hinges??
Any help would be GREAT!
Thanks,
SG
sgnden is offline   Reply With Quote
Old 11-28-2007, 11:48 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
You should have 3 holes now.. 2 for the screws to hold the handle on and the center hole for the new handle... My rover no longer has a handle either... I use a screwdriver to push in the plunger that releases the lathes.. and it opens right up for me!
Old 11-29-2007, 07:19 AM   #3 (permalink)
sgnden's Avatar
Funrover:
I stuck a screwdriver in there and tried pressing, pushing, twisting, looking for some activation/release mechanism and nothing happened...
Do you just push straight-in? Or is it to the side or some other angle?
Thanks!!
SG
Old 11-29-2007, 10:30 AM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
I just push straight... If yours is rather rusty you may try some PBBlaster to loosen it up some!
Old 11-29-2007, 11:13 AM   #5 (permalink)
sgnden's Avatar
Got 'er open a few minutes ago...just held the handle hard against the frame, pushed the button...and pulled out on the frame edge...bingo.
Dang it's cold out there in the wind up here in Parker!
Later,
SG
Old 11-29-2007, 10:28 PM   #6 (permalink)
Art Vigil's Avatar
Originally Posted by sgnden View Post
Hey...
Thanks,
SG
Just stick a screwdriver in the hole and push - at least that's how I opened the old tailgate on my '95 RRC when my handle came off. I used this method for several months until I finally replaced it with a new one.
You can also use your ignition key although I wouldn't recommend it for the possibility of damaging the key.
Best of luck,
Art Vigil
Denver City, CO USA
'95 RRC SWB TWR Edition
'72 Series III 88" (Rita)
'97 D90SW #2426 (sold 3/05)
'95 D90ST #2620 (sold 10/01)
Art Vigil is offline   Reply With Quote
F/S RRC Upper Tailgate Paul Grant Land Rover Parts and Accessories 2 11-25-2007 11:34 AM
Upper tailgate not staying latched..... HaroldC Range Rover Classic 18 11-13-2007 12:53 PM
Upper Tailgate weather-proofing RageRover Range Rover Classic 8 03-30-2007 08:15 AM
WTB 97' 4.6 HSE Upper Tailgate Bulb Housing Ezrelda Land Rover Parts and Vehicles Wanted 0 07-26-2006 06:10 PM
Upper tailgate adjustment Papaquebec Range Rover Classic 3 11-02-2004 01:28 PM
