Apologies if this is really already answered in a thread, but i couldn't find the answer after a bit of searching.
1991 classic (no airbag). removing the steering wheel. Have 1. removed the rubber cover from the wheel 2. disconnected electrical connector for the cruise control switches 3. removed the nut from the column shaft where it comes through the wheel Cannot get wheel off. There are two holes approx 6-7 milimeter each on opposite sides of the shaft. Shined a light in and examined these to see if there were bolts or anything to discconnect in there. Don't see anything. Is there anything else to disconnect or loosen? Or is wheel just stuck? Thanks
Pat Herman |
#3 (permalink) | |
so theres nothing more i need to do other than keep pulling?
Pat Herman |
Ian Matthews
Hitting it runs the risk of destroying the steering column as they are designed to collapse in an accident. Just go and buy a steering wheel puller from your auto store. The holes you mention either side is where the puller attaches. Then there is a centre bolt on the puller that goes onto the steering shaft. You just screw in the bolt on the puller and the steering wheel will come off.
![]() Join Date: Dec 2005
I agree with Ian on this one, a puller is easier, and less painful. I ate a steering wheel by trying to have a friend bash it, while I pulled. I believe you can rent a puller from an Autozone, or something like that.
thanks for the advice. will get a puller as I do not relish the thought of getting smacked in the face by the wheel. I'd probably bust more than that as i have the entire interior ripped out and nothing to land on but steel. ;-)
Pat Herman |
