I'm finishing up a hub seal replacement and have a question about the end float. This is what the manual reads:
Fit the hub inner nut and using wrench 606435 tighten the adjusting nut while slowly revolving the hub until all end-float is removed then back-off the nut approximately half a turn and retighten the nut to 13-15 in lb which will automatically allow for compression of the rubber on the new seal track spacer giving the required hub end-float of 0.013 to 0.10 mm (0.0005 to 0.004 in ). I am having one hellava time finding a 2 1/16 socket. Only one i can find in stock is $50.00 plus i would need a 1/2 adapter. I really don't want to pay this. I removed it with a larger adjustable wrench, but of course its hard to get a torque wrench on that. So, how darn important is the 13 -15 lbs? 15lbs isn't too much past hand tight. Use my best guesstimate or buy the socket? Opinions?
Greg M 1987 RRC Rovers haven't made it to the far reaches of the Earth worrying about warning lights. |
Greg,
Here's what you need. http://www.roversnorth.com/store/p-6...ped-steel.aspx As far as how tight to go, you're right, it's a little tighter than hand tight. You can do it without the hub nut tool but if you're planning on owning Rovers for the long haul the tool is well worth the purchase price. Cheers, Paul |
Ian Matthews
Basically do the inner nut up tight and then back it off until you can feel a very slight movement when rocking the wheel (hub). Then put on the lock washer on and tighten up the outer nut tight. After tightening the out nut you should feel no movement when rocking the wheel in and out. No need to worry about torque settings, etc.
X2
You want to tighten the first night nice and tight to be sure that the seal is all the way seated, if not you will get a false reading and end up with a loose hub. Back off an tighten with just your hands on the stamped socket, when your greasy sweaty hands slip on the socket is perfect.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. '91 RRC, bone stock |
#5 (permalink) | |
Make sure you seat the seal well, after my test drive I had to retighten both of mine, as there was too much float.
'81 RR 2dr "Miles" '89 RR 4dr parts '96 VW Jetta the driver |
Ian Matthews
Just make sure that you have put the seal into the hub to the correct depth, otherwise it will have the end taken off and you will be repeating the process in a few months.
| Thread Tools | |
| Display Modes | |
