Old 02-20-2006, 04:07 PM   #1 (permalink)
Question I read the other blower motor threads
My 91 RR is blowing plenty of heat at 60 mph plus ,even in the back seat, but no blower motor running on any setting that I can hear. The ac blowers are fine.
I too get cold air in the vents no matter what I select for the air flow lever.
i really do not want to rip out the unit because it was already done by a dealer 2 years ago. Is there a way to direct wire current to the blower motor to test it before I rip everything out??? can i circumvent the relays?
Okierover helped out last time but the resisitor was not the culprit!!! Help I am freezing !!!!:
corncarr is offline   Reply With Quote
Old 02-20-2006, 04:27 PM   #2 (permalink)
I have an 88- I "think" the only difference is my blower motor is on the right sdie of the heater unit, yours might be on the left (drivers) side.
My motor is connected with a 2 wire- ground and power- naturally the power wire is thru the resistors and relays-
but- Yes, you should be able to hook up 12vdc direct to the motor- just make sure your power and ground are correct- and it should spin the motor- fast. The resistor is there to give you med and slow speed- Check the wiring diagram schematic.
If your motor spins on 12vdc directly, then it's troubleshooting time- switch, relay, etc. Check the schematic!
Also, being new to RRC's myself, it was quite surprising to only have AC blow out the vents. However, I don't get cold air thru the vents unless I select the AC mode on the panel- mybe I gt a good seal somewhere???
Good luck.
Carl
Kleantouch is offline   Reply With Quote
Old 02-20-2006, 04:40 PM   #3 (permalink)
Good luck.
Carl
Thanks Carl...I did change the big resistor in the vent cowl and like i said did no good. I think i will change relays, pray to God, offer sacrifices to pagan rover gods, or whatever ...anything to test before i rip out the unit...I may just get lucky and it will be a relay
(yeah right ...after 23 years of Lucas elelctronics).
Are there wires going directly to the heater motor I can get to without totally pulling the dash and pulling the unit?
Old 02-21-2006, 05:59 AM   #4 (permalink)
Good luck with the relay replacement----
You might get to a connector by following the off-low-med-high blower switch from the control panel- a few screws should do it,
determine which side the motor is on- if on drives side, should have fairly good access- if under the passenger side, some panels will probably have to come off.
Good luck.
Carl
