Old 07-31-2006, 06:09 AM   #1 (permalink)
Default Id This
90 RR County
Have Factory grill guard for sale/trade
90RRClassic is offline   Reply With Quote
Old 07-31-2006, 03:31 PM   #2 (permalink)
Looks like a relay socket with melted wires.Where did you find that on the truck?
Triple R is offline   Reply With Quote
Old 07-31-2006, 03:45 PM   #3 (permalink)
RageRover's Avatar
x2, where is that connector located?
Kinda vague from the pic, but yeah it does look like something a relay would plug into.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 08-01-2006, 05:43 AM   #4 (permalink)
It is in fact a relay plug with some f00ked up wires.. but I dont know which one it is.. Found under front pass seat
90 RR County
Old 08-01-2006, 05:58 AM   #5 (permalink)
RageRover's Avatar
Did the truck at one point have EAS? That might be the relay socket for the system, not sure. I will have to look at mine, although mine is 4 years ahead of yours.
1995 RRC LWB
Old 08-01-2006, 06:11 AM   #6 (permalink)
I'm going with cruise control relay or condenser fan timing unit. The other 2 under there EFI (black) and fuel pump (blue).
Kevin
88 RRC "Audrey"
Old 08-01-2006, 10:56 AM   #7 (permalink)
The fuse for the fuel pump also continues to blow?
90 RR County
Old 08-01-2006, 01:49 PM   #8 (permalink)
I would definitely seperate those wires from each other,before further damage occurs. That also might cure your blowing fuse issue..
