Old 01-09-2008, 06:12 AM   #1 (permalink)
Default If it ain't broke..........
Well, I have to admit, I didn't follow that old adage. I have a 1995 RRC which was working great (apart fromt he usual RRC quirkiness ) but of course I decided to putz with it.
Over the weekend I replaced the plugs, distributor cap, plug wires, took out the K&N air filter and cleaned and re-oiled. In the process of doing this I broke the thin plastic tube to the vacuum advance in the distributor but replaced it with plastic tubing. After all this I started the engine and checked it was firing right (I hate changing plug wires on a V8) and all was good. All in all a good days work I thought as I cleaned my grimy hands. Doh !
When we got back on the road I had seriously reduced power, a juddering above 35/40 mph and a blue cabin with all the curses.
Went back home and replaced the new cap with the old one, hoping this would fix it, but no change then on the drive to work the next day. Next steps is to replace the new plug wires with the old ones and see what happens. However, I thought I might call ont he collective experience and knowledge here to see if you can spot anything idiotic I may have missed !
AndrewG is offline   Reply With Quote
Old 01-09-2008, 06:42 AM   #2 (permalink)
Elemental's Avatar
Whose plugs did you use?
Old 01-09-2008, 06:56 AM   #3 (permalink)
Champion Platinum. However, more reading around and looking at the websites I realised that my local carshop gave me Disco I spark leads while all the Rover sites have different spark leads for RRC !
Old 01-09-2008, 07:02 AM   #4 (permalink)
Elemental's Avatar
I think you would be smarter to confirm your centrificle advance and vacuum advance is working.
The plug wires from a disco will work just fine.
Old 01-09-2008, 08:25 AM   #5 (permalink)
rqsall's Avatar
Make sure you replaced the distributor cap with a genuine item and not an imitation/pattern part. I've heard many stories about this issue and didn't take the risk of getting a non-genuine one, but it's a recurring issue on quite a few forums.
1991 RRC 3.9 EFI
manual gearbox (LT77)
rqsall is offline   Reply With Quote
Old 01-09-2008, 01:33 PM   #6 (permalink)
I put the original cap back and the problem is still there.
How would I test the vacuum advance ?
Old 01-09-2008, 04:20 PM   #7 (permalink)
fuddmucker
pie4foou's Avatar
Gallery: 2
has to say lucas on the rotar too... found that out the hard way.
pie4foou is offline   Reply With Quote
Old 01-09-2008, 07:52 PM   #8 (permalink)
Learned that the hard way on a TR7 a few years back Lucas, the Prince of Darkness !
I was clever this time, well apart from it doesn't work after the changes, but at least I left the rotor alone !
Old 01-10-2008, 05:13 AM   #9 (permalink)
Couple of other thoughts to check...
-air gap in the distributor
-plug gaps
-blockage in the air intake
Kevin
88 RRC "Audrey"
Kevin88RRC is online now   Reply With Quote
Old 01-11-2008, 06:08 AM   #10 (permalink)
Taking a few hours today to go over the suggestions you guys offered. I'll let you know how I get on !
Broke the slip yoke mowthat Discovery Series II 0 03-18-2007 01:53 AM
Rear Support Strut broke, JB Weld tips needed Sign Guy Range Rover Classic 2 02-19-2007 08:02 AM
The websites Kelli doesn't want you to see. Broke back II Previews. DevilDisco The Lounge 3 07-13-2006 10:04 AM
Oops.....I broke my 109"! Cerberus General Land Rover Discussion 5 01-03-2006 07:55 AM
My moonroof sunshade broke :-( champagnerange Discovery Series II 7 10-05-2005 09:41 AM
