Old 09-01-2004, 07:54 PM   #1 (permalink)
LRO Founder
Serg's Avatar
Default Ignition key won't come out..
On my '95 LWB I am having a hard time removing the key from the ignition. When you get to the point where you have to depress the key and rotate it a bit more, the key cylinder won't allow me to depress it.. I notice if I fiddle around with the gear selector (automatic) it will do it.. I wonder if there is something loose in the gear selector lever mechanism and hence I can't get the key out...
Serg
Current Vehicles:
2003 BMW 540iT M Sport
2005 BMW R1200GS
2004 Element Skateboard (Indy trucks, Bones Swiss, etc...)
Past LR's:
1995 Range Rover LWB Classic
1997 Discovery XD
1995 Range Rover LWB Classic 4.0
Serg is offline   Reply With Quote
Old 09-01-2004, 08:13 PM   #2 (permalink)
Sometimes the switch in the gear selector sticks. At least thats whats wrong with mine.
By putting your foot on the brake pedal and lightly flicking the lever on the bottem of the shifter up and down while in park you might hear a light metallic "ping" in the steering wheel column near the ignition switch. This is the mechanism preventing you from removing the darn key. After doing this for a few seconds you should be able to remove the key. The only other time this happened was when my battery was almost dead. Charging up the battery took care of that problem.
Good Luck
korn_rover is offline   Reply With Quote
Old 09-20-2004, 07:42 AM   #3 (permalink)
troverman's Avatar
The ignition switches in the Classics were / are extremely tempermental. I had just gassed mine up at a busy gas station, paid for the gas, and couldn't get the car started for about an hour! (Blocking the pumps, of course) The key wouldn't turn in the cylinder.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 09-21-2004, 06:31 AM   #4 (permalink)
Tim_H's Avatar
I had the same problem with my 1992. I eventually shot WD-40 into the switch and it solved it. However I was told that graphite might be the better way to go as it will last longer.
Tim_H is offline   Reply With Quote
