Old 01-08-2008, 08:53 AM   #1 (permalink)
OkieRover's Avatar
Gallery: 2
Default Ignition Light on when Key off
Just before Christmas my daughter reported that there was a light on in the Range Rover. I went out and found the "ignition light". The one that looks like a battery glowing all red.
I took the rover down to OReilly's and they told me that the alternator was putting out 15+volts. That's not right.
Well I had bought a NAPA alternator and had a lifetime warranty and thusly asked them to get me another in. Last Friday it came in, yeah I know, sloooooooooow service.
Last night I installed the new alternator and I still have the light.
With the battery connected I can hear a very high pitched sound from the alternator. With the battery disconnected the sound is not present.
I am guessing I have a dead short. Why I'm guessing this is the battery drains to zero over night. I had a battery charger on it before I replace the alternator and could only get the charge on the battery back to 50%.
Anyone got any ideas?
I punch my clown daily.
Old 01-08-2008, 07:30 PM   #2 (permalink)
defective diodes in the alternator/defective alternator will cause your problem, voltage and amperage output are not the only things to check on an alternator, quite unfurtunately most places use this method to diagnose an alternator.
carlosz is offline   Reply With Quote
Old 01-14-2008, 11:17 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
It looks like it wasn't the 2nd alternator after all.
I took it out and when I looked at the back the wire that goes to the center post was shorted against the Positive post going to the battery.
Either I pinched it on there or the factory did.
Anyway it's back on the road.
Ignition Warning light on, tach working 92rrcl Range Rover Classic 2 01-17-2007 10:14 AM
Ignition and rear seat dome light stays on CurryHook Discovery Series II 2 12-09-2006 12:01 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 05:46 PM
battery/no charge light on without ignition Gareth Rhys Jones Defender 1 10-21-2005 09:14 PM
