1990 Classic Rover
Having a bit of a problem with my ignition switch. It seams I might of broken the tip of the key in the switch. I can not turn the switch with the key although I can not see any thing in there. WD-40 does not help. I have the covers off but having a hard time with the shear bolts. What size are the heads? Any ideals? Thanks, bernie |
Whenever I remove an ignition switch assembly I always use a Dremel to cut a slot in the shear bolt so that I can back the bolt out with a screwdriver. That way, you can even use the bolts over again if you need to.
Got the slots cut and shear bolts out.
Took switch to locksmith, got the key tip out. Got all back togather, life is good. Thanks for your help again bernie |
| Thread Tools | |
| Display Modes | |
| replacing ignition switch | chrisusvi | Discovery Series I | 1 | 04-29-2007 08:06 AM |
| [All] Pre 96 OBD1 Fault Codes | TerryS | Tech & DIY | 0 | 01-26-2007 07:00 AM |
| P38 ..Non-Starter!! | Fozzy | Range Rover P38, Mk III and Range Rover Sport | 25 | 04-12-2006 03:50 AM |
| 99 4.6 is superlocked and won't reset | Spring | Range Rover P38, Mk III and Range Rover Sport | 9 | 12-05-2005 04:46 PM |
| Problem with the window wipers | JP-NORWAY | Defender | 2 | 09-02-2004 09:06 PM |
