Old 03-05-2008, 12:46 PM   #1 (permalink)
Default Ignition Switch
1990 Classic Rover
Having a bit of a problem with my ignition switch.
It seams I might of broken the tip of the key in the switch.
I can not turn the switch with the key although I can not see any thing in there.
WD-40 does not help.
I have the covers off but having a hard time with the shear bolts.
What size are the heads?
Any ideals?
Thanks,
bernie
Bernard Thompson is offline   Reply With Quote
Old 03-05-2008, 01:30 PM   #2 (permalink)
Whenever I remove an ignition switch assembly I always use a Dremel to cut a slot in the shear bolt so that I can back the bolt out with a screwdriver. That way, you can even use the bolts over again if you need to.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 03-05-2008, 05:06 PM   #3 (permalink)
Thank you Paul I will try that tomorrow.
Do thes switches just ware out?
Old 03-06-2008, 04:51 PM   #4 (permalink)
ohiorover's Avatar
yes they do, Paul actually hooked me up with a used one a few years ago. Before that I kept it going by using graphite power.
ohiorover is offline   Reply With Quote
Old 03-06-2008, 06:12 PM   #5 (permalink)
Got the slots cut and shear bolts out.
Took switch to locksmith, got the key tip out.
Got all back togather, life is good.
Thanks for your help again
bernie
replacing ignition switch chrisusvi Discovery Series I 1 04-29-2007 08:06 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 09:06 PM
