Old 03-07-2005, 10:38 AM   #1 (permalink)
Default Inner door release
I'm having a hard time trying to adjust the front passenger inner door release. Shop manual says "Rotate the spring tensioned nyloc nut at the opposite end of the interior handle connecting rod, clockwise or counter-clockwise to shorten or extend the operating length". I understand that, but how do you access it????? It now takes quite a few pull on the lever to open the door and that does not make the wife happy
Kevin
88 RRC "Audrey"
Old 03-07-2005, 11:58 AM   #2 (permalink)
Default Long shot - Take the inner panel and trim off
I belive thst is only way to access the inner mechanism for the door.
AdrianL is offline   Reply With Quote
Old 03-07-2005, 12:24 PM   #3 (permalink)
Yeah that's a must, but what the pic fails to show clearly is that the mechanism is still behind a metal piece of the door. It's a blind shot at the adjuster. I guess I'm looking for tips or tricks to get at the adjuster nut.
Kevin
88 RRC "Audrey"
Old 03-07-2005, 01:26 PM   #4 (permalink)
Default I hear ya.
I did similar thing to my wife's discovery (changed window regulator) and the metal plate in front of the mechanism is just PITA to manuver things around to get to. I guess only thing ca be done is to take the mechanism out and adjust the nut and reinstall.
Old 03-09-2005, 03:57 PM   #5 (permalink)
A quick fix is to use two pairs of pliers and put a kink in the rod to shorten it
Mick
scoobymick is offline   Reply With Quote
Old 03-09-2005, 06:17 PM   #6 (permalink)
yeah, the nut on the end of the threaded shaft is tough to access, and you may question your sanity before you finish the job, but the best way i've found to adjust it is to use a "sacrificial wrench"..........whats a sacrificial wrench, you ask? lol...well, its a wrench you've had to sacrifice to do the job, of course(yeah, i felt kinda dumb writing that)...take a 7 millimeter wrench (if my memory is correct, that is the size of the nut) and cut the open end off to a length of approximately 2 inches, this will be close to the correct length...you should now be able to make small adjustments to the nut in the desired direction...take your time and try not to get too frustrated, as this will test your patience........and yes, you must thread your entire arm/hand up into the latch area through one of the door panel openings
hope this helps
son of lucas is offline   Reply With Quote
Old 03-09-2005, 10:29 PM   #7 (permalink)
Thanks s.o.l. At least knowing it might be 7 mil is a start and the whole yoga thing is side the door is fun. If I cant get at it, then I'm going with Mick's route.
I'm away for a couple weeks so I will let you know how it goes when I get back.
Kevin
88 RRC "Audrey"
