Links
Old 05-07-2008, 12:46 PM   #1 (permalink)
ChamplianRover
Default I've Put it Off Long Enough
Time for new gaskets for the exhaust manifolds. There is exhaust leakage and an awful ticking that I first thought was tappets, then catalytic converter, then water pump...but finally narrowed down to one of the manifolds.
So, how do I get the 13 year old rusted, fused bolts out without breaking them???
Thanks,
ChamplainRover
ChamplainRover is offline   Reply With Quote
Old 05-07-2008, 03:57 PM   #2 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
Spray liberally with PB Blaster for 2-3 days before hand. If that doesn't work try a little heat to the nuts...a propane torch woks nicely. Plan on new nuts...oh and apply anti-seize when reinstalling.
Solution or Problem...Which are you?
1994 RRC LWB, 82k miles, 4.2, Cornish Cream/Lightstone Interior, spring converted.
BullDogSix is offline   Reply With Quote
Old 05-08-2008, 06:31 AM   #3 (permalink)
Also, if you don't want to reuse the factory locking clip things, (what a PITA those are to reinstall!) make sure you use new lock washers. I've seen seemingly good used ones lose the temper in the lock part and let the bolts back out.
'95 RRC LWB, '05 Suburban Z71 (not stock), '94 F350 (very ugly), '62 International 404 tractor (red & white) & many other project cars in the past!
57loboy is offline   Reply With Quote
Long Arm Anyone? TsiArt Discovery Series II 10 08-30-2007 03:34 AM
The PowerChip Experience...So Far (Long) DevilDisco Discovery Series II 15 06-18-2007 12:17 PM
Land Rover Frequently Asked Dumb Questions (very long...but funny) JungleRR General Land Rover Discussion 0 05-26-2006 09:37 AM
WARNING: LONG POST - Another LR Embarrassing Moment... 01001010 Off Road 13 08-14-2005 10:23 AM
Long Brake Pedal Syndrome? PCrover Discovery Series II 21 06-29-2005 10:12 AM
