Hey everyone...
Just a quick question. Any tricks or talents I should have up my sleeve in changing the oil pan gasket? I would think it's pretty straight forward, but about the time I think that.... Well.... you know. If not, great, but if any of you have replaced yours and can offer advice, or at least a good story, I'd appreciate your time! ![]()
"The trouble with the rat race is that even if you win, you're still a rat." -Lilly Tomlin 1990 RRC SWB
Its very straight forward. Undo the wires for the oil level sensor. Buy some gasket sealer (no 2 I think), the black stuff that remains pliable - to hold it in place while you bolt it on.
There is a specific tightening sequence for the bolts. You'll want to clean the bottom of the pan and the screen for the oil pump pickup tube. That's it really.
Greg M 1987 RRC Rovers haven't made it to the far reaches of the Earth worrying about warning lights. |
Or you can ditch the gaskets entirely and go with the Right Stuff or black Permatex. I used the Right Stuff on my truck 6K miles ago and the seal has held up well. The key is to get the mating surfaces as clean and dry as possible before applying the sealant.
![]() Join Date: Dec 2005
Plus I notice that Corked gasket material leaks sometimes, so IMHO they should be used mostly for intake accesories like IAC/V, etc..
Rubber ones are ok, as long as you don't tighten the bolts too hard. But using the paper style material and some RTV, works real good, never had a problem with that for oil pans, and valve covers.
#6 (permalink) | |
Otherwise known as STEVE
Make sure you take off all the bolts. Sounds like stupid advice, but people try to pry them off without looking to see if all the bolts are out and mess 'em up ALL the time. I'd make a gasket, personally... but whatever floats your boat.
#8 (permalink) | |
I refuse to tip toe through Life only to arrive safely at Death ![]() Rocks, Sand, Mud, Water whatever I just want to leave the pavement Its your Life, LIVE it ENJOY it!
