Old 06-06-2006, 06:43 PM   #1 (permalink)
Gillah11's Avatar
Default Just a quickie...
Hey everyone...
Just a quick question.
Any tricks or talents I should have up my sleeve in changing the oil pan gasket? I would think it's pretty straight forward, but about the time I think that....
Well.... you know.
If not, great, but if any of you have replaced yours and can offer advice, or at least a good story, I'd appreciate your time!
"The trouble with the rat race is that even if you win, you're still a rat."
-Lilly Tomlin
1990 RRC SWB
Gillah11 is offline   Reply With Quote
Old 06-06-2006, 07:56 PM   #2 (permalink)
Greg M's Avatar
Its very straight forward. Undo the wires for the oil level sensor. Buy some gasket sealer (no 2 I think), the black stuff that remains pliable - to hold it in place while you bolt it on.
There is a specific tightening sequence for the bolts.
You'll want to clean the bottom of the pan and the screen for the oil pump pickup tube.
That's it really.
Greg M
1987 RRC
Rovers haven't made it to the far reaches of the Earth worrying about warning lights.
Greg M is offline   Reply With Quote
Old 06-06-2006, 08:00 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
Make sure you get a paper (cardboard) gasket and not a cork one. The cork ones tend to spread when you tighten up the bolts.
Ian
Old 06-06-2006, 08:19 PM   #4 (permalink)
Or you can ditch the gaskets entirely and go with the Right Stuff or black Permatex. I used the Right Stuff on my truck 6K miles ago and the seal has held up well. The key is to get the mating surfaces as clean and dry as possible before applying the sealant.
Old 06-06-2006, 11:46 PM   #5 (permalink)
RageRover's Avatar
Plus I notice that Corked gasket material leaks sometimes, so IMHO they should be used mostly for intake accesories like IAC/V, etc..
Rubber ones are ok, as long as you don't tighten the bolts too hard. But using the paper style material and some RTV, works real good, never had a problem with that for oil pans, and valve covers.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 06-07-2006, 05:19 AM   #6 (permalink)
sven's Avatar
X2 on the Right Stuff. I think LR even stopped using pan gaskets after 95.
Old 06-07-2006, 07:23 AM   #7 (permalink)
Otherwise known as STEVE
Make sure you take off all the bolts. Sounds like stupid advice, but people try to pry them off without looking to see if all the bolts are out and mess 'em up ALL the time. I'd make a gasket, personally... but whatever floats your boat.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 06-07-2006, 08:03 AM   #8 (permalink)
I used the benz black sealant and I will have to pry the damn thing off after using a gasket cutter when I do my rear main, However that thing will never leak form the oilpan again....ever... I love Benz black sealant just don't put it on anything you want to easily get apart any time soon. And for something a little less hardcore I prefer the grey Hondabond, both can be had from their respective dealerships
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
