Old 10-07-2004, 11:31 PM   #1 (permalink)
Default Key broke off in ignition
It is day six with my new rover, and after working on the interior for a few hours I drove to the store, turned her off and pulled half of the key out! I can get her started, but it is kind of tricky. Has this happened to anyone else? Is the tumbeler exchange pretty straight-forward?
Thank you,
Pat
'88 Range Rover
'83 Mercedes 300D
Kilauea, Kaua'i
Papaquebec is offline   Reply With Quote
Old 10-08-2004, 11:28 AM   #2 (permalink)
hamrendan's Avatar
Default Lock Smith ??
Dan Hamren
93 LWB "Dubya" AKA "The Beast"
hamrendan is offline   Reply With Quote
Old 10-08-2004, 12:43 PM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
Once you get down into the column it looks pretty easy. But you may want to have a locksmith do the work if you are worried about it.
I punch my clown daily.
Old 10-08-2004, 02:29 PM   #4 (permalink)
Default Tumbler
Where's the best place to but the tumbler??
Pat
'88 Range Rover
'83 Mercedes 300D
Kilauea, Kaua'i
Old 10-08-2004, 07:38 PM   #5 (permalink)
Landy-Andy's Avatar
Default Broken off key in ignition....
Hi,
I was able to retrieve half-a-key once by just adding a tiny dot of a good quality, fast acting super glue to the end of the key you still have, push it firmly into the ignition so it pushes against the broken off part (I gave it about 20 seconds) then pull it out slowly & carefully as straight as possible.
Now the secret to this working is just to use a tiny dot of glue & make sure its a good quality glue that bonds on impact.
Worth a try before to take the tumbler apart!
Good luck,
Andy-Landy
Landy-Andy is offline   Reply With Quote
Old 10-09-2004, 12:20 AM   #6 (permalink)
That is a good idea, BUT, I am not sure if I have another key! I will check tomorrow to see if the extra key I do have is for the doors or tailgate (the doors, tailgate and ignition were all different).
Thank you,
Pat
'88 Range Rover
'83 Mercedes 300D
Kilauea, Kaua'i
Old 10-09-2004, 09:12 PM   #7 (permalink)
OK, that was my only key. How diffacult is it to replace the tumbler? I found one w/ key listed for 79.00
Pat
'88 Range Rover
'83 Mercedes 300D
Kilauea, Kaua'i
