Old 02-21-2007, 07:44 PM   #1 (permalink)
trellis8's Avatar
Default Key stuck in ignition!
Anyone have any ideas how to remove a key from the ignition switch of a '93 Rover lwb. It is an aftermarket key that has been working fine. It turns to the proper off position but I can't pull it out. Thanks.
trellis8 is offline   Reply With Quote
Old 02-21-2007, 08:01 PM   #2 (permalink)
Nomar's Avatar
It's probly not the key. There is a relay that keeps the key in the ign until it's in Park, etc. I'm not sure where it's located, I just disconnected the wires to that part of the ignition switch that holds the key in on my '93 LWB.
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done."
Nomar is offline   Reply With Quote
Old 03-04-2007, 09:44 PM   #3 (permalink)
ryans ROVER
ryanc8514's Avatar
mine does this too, shift the shifter forward until you hear it click then turn the key forward and back, it should come out after playing with the shifter and the key position
ryan mura
1994 range rover county lwb
-BIG BLUE 3" coil spring suspension lift
-Procomp ES3000 shocks
-custom snorkel
-glasspack exhaust system
-285/75/R16 all terrain tires
-old school CB radio from the 80s-cobra
-speakers loud enough to set off car alarms
-LR3 side air vent
ryanc8514 is offline   Reply With Quote
Old 03-05-2007, 05:48 PM   #4 (permalink)
LRR219's Avatar
hopefully you have it out by now... but if not... get a pair of needle nose plyers... open them slightly to that they fit just over the key... dont close them on the key but push in the center of the ignition switch so that the you can remove the key... many aftermarket keys are to large and will not allow you to push it past the illumination ring or equivalant of that on a county.. once you press the center of the ignition switch in you sould be albe to remove the key... if you have any quesions about my mess above pm me!
Don't follow us, you'll get stuck.
LRR219 is offline   Reply With Quote
Old 03-06-2007, 06:12 PM   #5 (permalink)
singingcamel
singingcamel's Avatar
follow nomars advise and the key will come out. you may need a new ignition switch
singingcamel is offline   Reply With Quote
