Old 07-19-2008, 06:42 AM   #1 (permalink)
Default Key stuck in ignition
Hey, I have a 94 classic with the key stuck in the ignition. It still works fine but will not come out when switched in the off position. It's draining my battery, when I dissconnect the battery the key releases from the ignition. Anyone know where the relay for the interlock solenoid is located? Thanks for the help.
collins is offline   Reply With Quote
Old 07-19-2008, 03:13 PM   #2 (permalink)
Ambo's Avatar
Is this your normal key ?, or was it a spare that was cut, and never used before ?
Sometimes keycutters cut a key on the wrong blank ie too short.
As the key needs to be pushed in to remove it on the last part of the rotation, the key wont if too short.The only way to remove it , is to get some cutters and cut the sides of the head off, to allow the key to be pushed in.
Mike - the Locksmith.
Ambo is offline   Reply With Quote
Old 07-20-2008, 05:31 AM   #3 (permalink)
Mike, this is the original key.
Thanks
Old 07-21-2008, 11:49 PM   #4 (permalink)
Aarons312's Avatar
Try this, it worked for me.
If your key gets stuck in the ignition, do this
It's under the Tech/DYI section on the forum if the link dosn't work. I actually got tired of it and just zip tied it in the up "unlocked" position.
Aarons312 is offline   Reply With Quote
Old 07-27-2008, 09:18 AM   #5 (permalink)
I love to use my ...
User's Avatar
I had the same problem with my RR. In my case, it was a failure of the "park" postion switch. I removed my steering colomn cover and cutted a purple wire near the ignition swith and it solved my problem.
User is offline   Reply With Quote
Key stuck in the ignition DWN4WVR Range Rover Classic 3 05-03-2008 08:44 AM
If your key gets stuck in the ignition, do this etischer Tech & DIY 2 08-06-2007 10:44 AM
Key stuck in ignition! trellis8 Range Rover Classic 4 03-06-2007 05:12 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
