Old 01-24-2008, 02:44 PM   #1 (permalink)
ChamplianRover
Default Leaking Coolant Mystery
Classic Gurus,
I've removed the steering pump to get a better look at my water pump area.
I've located the coolant leak. When I pour coolant into the expansion tank (motor not running), it fairly immediately leaks out of a small hole in the gasket between the "top cover" and the engine block!
Any clues on how this could be possible and how I should proceed?
Thanks,
ChamplainRover
ChamplainRover is offline   Reply With Quote
Old 01-24-2008, 03:10 PM   #2 (permalink)
it is a land rover, anything is possible.
coolant leak = auto flush of cooling system
oil leak = auto lube and rust protecction
broken parts = the vehicle acknoledges a part needs replacement so it lets you know it.
no start = a way of telling you to stay put no need to go anywhere
lock out = showing off its anti theft protection
non working electricals = dont need to use it anyways, conserve energy
poor mpgs = me and only me shall be allowed to use oil reserve
slow on fast lane = I dare you to make me move
costly repairs = you bought me not the other way around
does not pass smog test = who is the goverment to tell me I cannot burn my fuel improperly.
does not pass safety inspection = I am an english gentleman damm it....kiss my royal britt ass.
and then you wonder what makes a rover a rover....................go figure.
carlosz is offline   Reply With Quote
Old 01-25-2008, 04:57 PM   #3 (permalink)
ChamplianRover
Not sure what to do with the post above, but it isn't helpful.
I really need and would appreciate advice.
Thanks,
ChamplainRover
Old 01-26-2008, 02:33 PM   #4 (permalink)
just meant as sarcastic comedy about "the land rover experience"
Old 01-26-2008, 05:05 PM   #5 (permalink)
OkieRover's Avatar
Gallery: 2
That's the head gasket.
It's gonna have to be replaced.
While you have the heads off get a "head job". It will be giving your top end new life and your engine too.
I punch my clown daily.
Old 01-27-2008, 08:45 AM   #6 (permalink)
ChamplianRover
Okie,
Thanks. Email sent.
ChamplainRover
95 SWB smells like coolant and blows air bubbles kkrover Range Rover Classic 33 02-15-2008 07:34 AM
Small Coolant leak...Blow Head Gasket? maverick544 Discovery Series II 9 09-22-2007 08:27 AM
p38 leaking coolant, help. mikecarport Range Rover P38, Mk III and Range Rover Sport 6 08-27-2007 10:05 AM
coolant leaking under floorboards??? ryanc8514 Range Rover Classic 6 06-19-2006 10:00 AM
need help with leaking coolant GOTMUD? Discovery Series II 4 02-22-2006 04:08 PM
