Old 05-15-2008, 08:57 AM   #1 (permalink)
Default leaking front abs caliper 8 months old wtf
guys my right front abs caliper is leaking fluid drip drip drip, even when parked. the caliper is abs and about 8 months old. cannot recall if it's a remanufactured or brandy new. all the bleeders are tight etc.
wondering what it might be ?? stuck piston, bad seal kit, and what a cheap quick fix is if the parts supplier won't replace under guarantee.
thanks
wjones1396 is offline   Reply With Quote
Old 05-26-2008, 11:49 AM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
Replace the seals if its the pistons that are leaking. It's cheap and easy to do.
I punch my clown daily.
Old 05-26-2008, 02:26 PM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
did you make sure the hose connection and bleeder are good and tight?
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-31-2008, 02:28 PM   #4 (permalink)
Eric D's Avatar
Are you sure the caliper is at fault?
Mine leaked from one of the 2 hoses going to the caliper.
John Gadd supplied me with a used hose to get me by.
The hose had a tiny pin hole, but big enough to loose all the fluid after a few stops.
Luckily for my family and I, we were near home and arrived safely.
Braking was a chore, but keep your distance and plan your stops well in advance. Two foot braking is required for panic stops.
After this incident, I purchased braided teflon hoses on-line when they were on special. I have not installed them yet, when I'm 100% better, it will be on my to do list.
Also wanted to add, that the front calipers have a tiny o-ring for the 2 halves.
This is not a common leak, but should be mentioned as many re-builders never take the caliper halves apart.
The pistons can pit and cause leaks, some re-builders just wire brush them and reinstall. The piston seals are another source of leaks, if one purchases inferior quality products. Stick with an OEM brand for piece of mind.
I don't know what else I can add, that's pretty much it.
Eric D is offline   Reply With Quote
Brake Caliper Sheared Off! Help! AZROVER Discovery Series I 3 12-04-2007 02:36 PM
Disco II TD5 with leaking front sunroof medusan Discovery Series II 3 01-03-2007 04:34 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
Did Front Brakes, Now this... RageRover Range Rover Classic 6 06-12-2006 08:20 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
